I setup LTM according to article 404 Page not found | BIG-IP Documentation . According to BIG-IP XUI everything looks fine. All Virtual Servers & nodes & pool are green , but can not access to Virtual Server from browser https://10.100.223.200:8443 (VS- pool - 2 nodes). According to netstat output port 8443 is not open . Could you please help to troubleshoot the issue .
tmsh list /ltm
ltm default-node-monitor {
rule icmp
ltm dns analytics global-settings { }
ltm dns cache global-settings { }
ltm dns nameserver ns93 {
address 10.100.93.1
route-domain 0
ltm global-settings connection { }
ltm global-settings general {
maintenance-mode enabled
snat-packet-forward enabled
ltm global-settings traffic-control { }
ltm node node01 {
address 10.100.222.41
description node01
logging enabled
session monitor-enabled
state up
ltm node node02 {
address 10.100.222.42
description node02
logging enabled
state up
ltm persistence global-settings { }
ltm persistence source-addr PCOIP {
app-service none
defaults-from source_addr
ltm pool http_pool {
members {
node01:http {
state up
node02:http {
state up
monitor gateway_icmp
ltm profile client-ssl RAA-cert-test {
app-service none
cert default.crt
cert-key-chain {
default {
cert default.crt
key default.key
chain none
defaults-from clientssl
inherit-certkeychain true
key default.key
passphrase none
ltm profile http XFF {
app-service none
defaults-from http
proxy-type reverse
ltm profile server-ssl ccmqa.com-ssl-test {
app-service none
defaults-from serverssl
ltm rule DirectAccess_NLS {
HTTP::respond 200
ltm virtual http_vs02 {
destination 10.100.223.20:http
ip-protocol tcp
mask 255.255.255.255
pool http_pool
profiles {
tcp { }
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 8
ltm virtual https_vs01 {
destination 10.100.223.15:https
ip-protocol tcp
pool http_pool
profiles {
RAA-cert-test {
context clientside
tcp { }
source 0.0.0.0/0
type automap
vs-index 7
ltm virtual vs03_https {
destination 10.100.223.200:pcsync-https
ip-protocol tcp
persist {
ssl {
default yes
pool http_pool
profiles {
RAA-cert-test {
context clientside
tcp { }
source 0.0.0.0/0
type automap
vs-index 9
