Issue validate token
What need to get f5-oauth2/v1/Introspect?
token => access_token client_id => xxxxx client_secret => xxxx
Shows
/Common/OAuth:Common: Request Introspect Token from Source ID xxxxxxxxxx IP xx.xx.x.xxx failed. Error Code (invalid_request) Error Description (Invalid parameter (token).)
Hi did you fix your problem?
Because If you still reach a solution I find IT, keep me update
