I am trying to upgrade the software image on a BigIP VCMP guest using ansible. While I am able to perform almost all the tasks, the installation of UCS file(module used: bigip_ucs) is not getting complete. The task gets stuck and never proceeds further. However, on checking the system the installation seems to have completed with the system waiting for sync(next task in playbook). Can someone suggest how to proceed further? Following is the sequence of tasks that I am doing.
- Fetch the master key from vm (Module: bigip_command)
- Set the hostname (Module: bigip_hostname)
- Download a new UCS file (Module: bigip_ucs_fetch)
- Shut down current Guest (Module: bigip_vcmp_guest)
- Delete the vcmp guest & delete the virtual disk (Module: bigip_vcmp_guest)
- Create a new guest (Module: bigip_vcmp_guest) Power Up new guest (Module: bigip_vcmp_guest)
- Set the hostname (Module: bigip_sys_global)
- Login and Disable initial config (Module: bigip_sys_global)
- Save the running configuration of the BIG-IP (Module: bigip_config)
- Provision modules (Module: bigip_provision)
- Reinstate the master key (Module: bigip_command)
- Upload & Install the UCS file (Module: bigip_ucs) ---- This is where the playbook hangs
- Sync Group (Module: bigip_configsync_action)
- Remove the uploaded UCS file (Module: bigip_ucs)
Following is my playbook:
(f5_poc) -bash-4.2$ cat f5_upgrade.yaml
- hosts: f5 connection: local gather_facts: False vars_files:
- creds.yml
- “{{upgrade_info}}”
tasks:
Configure User
- name: Configure User
tags:
- run
set_fact:
provider:
user: "{{username}}"
password: "{{password}}"
validate_certs: no
admin_user:
user: admin
password: admin
timeout: 360
validate_certs: no
delegate_to: localhost
Fetch the master key from the vm
- name: Fetch the master key from vm
tags:
- run
bigip_command:
provider: "{{provider}}"
server: "{{ ip_addr }}"
commands: shell f5mku -K
register: cmd_output
- name : Setting the master key
tags:
- run
set_fact:
master_key : "{{ cmd_output.stdout | regex_replace('^..|..$', '') }}"
Download the software image on host
- name: Upload the software image on host
tags:
- dont
bigip_software_image:
image: /tmp/BIGIP-12.1.3.7-0.0.2.iso
server: 172.18.224.4
force: yes
state: present
server_port: 443
transport: cli
ssh_keyfile: /afs/athena.unimelb.edu.au/user/a/ankurm/.ssh/known_hosts
Set the hostname
- name: Set the hostname
tags:
- run
bigip_hostname:
server: "{{ip_addr}}"
hostname: "{{vm_to_upgrade}}.unimelb.net.au"
validate_certs: no
Create the UCS file to restore at the end
- name: Download a new UCS file
tags:
- run
bigip_ucs_fetch:
server: "{{server_name}}"
src: "{{ vm_to_upgrade }}-init.ucs"
dest: "/tmp/{{ vm_to_upgrade }}.ucs"
Shut down current Guest:
modify vcmp guest lb1-266-1-dev state configured
- name: Shut down current Guest
tags:
- run
bigip_vcmp_guest:
state: disabled
mgmt_address: "{{ ip_addr }}/{{ nw_bits }}"
mgmt_network: bridged
mgmt_route: "{{gateway}}"
Delete Guest:
delete vcmp guest lb3-396-2-dev
- name: Delete the vcmp guest & delete the virtual disk
tags:
- run
bigip_vcmp_guest:
state: absent
delete_virtual_disk: yes
Create new Guest:
- name: Create a new guest
tags:
- run
bigip_vcmp_guest:
state: configured
allowed_slots: "{{allowed_slots}}"
number_of_slots: "{{number_of_slots}}"
min_number_of_slots: "{{min_number_of_slots}}"
cores_per_slot: "{{cores_per_slot}}"
initial_image: "{{sw_image}}"
vlans: "{{vlans}}"
Power up the Guest:
- name: Power Up new guest
tags:
- run
bigip_vcmp_guest:
state: present
Set the hostname
tags:
- run
bigip_hostname:
provider: "{{admin_user}}"
Disable Initial Setup of the guest
- name: Login and Disable initial config
tags:
- run
bigip_sys_global:
gui_setup: no
Save running Config
- name: Save the running configuration of the BIG-IP
tags:
- run
bigip_config:
save: yes
Provision Modules
- name: Provision modules
tags:
- run
bigip_provision:
module: "{{item}}"
state: present
level: nominal
loop: "{{provision_modules}}"
- name: Reinstate the master key
tags:
- run
bigip_command:
commands: "shell f5mku -r {{master_key}}"
commands: shell f5mku -r GZIwzAaSeTu/EIcOHqT7FQ==
Upload and install the UCS file
- name: Upload the UCS file
tags:
- run
bigip_ucs:
force: yes
state: present
ucs: "/tmp/{{ vm_to_upgrade }}-init.ucs"
- name: Install the UCS file
tags:
- run
bigip_ucs:
force: no
state: installed
no_license: yes
no_platform_check: yes
include_chassis_level_config: no
- name: Sync Group
tags:
- run
bigip_configsync_action:
device_group: "{{item}}"
sync_device_to_group: yes
server: "{{sync_device}}"
overwrite_config: yes
loop: "{{sync_groups}}"
- name: Remove the uploaded UCS file
tags:
- run
bigip_ucs:
state: absent
ucs: "{{ vm_to_upgrade }}-init.ucs"
Using Ansible version 2.7
thank you for sharing.
I am facing issue with ISO-upload task. it times out after certain size of the image/ won’t finish uploading entire image.
I work over VPN and using wireless connection. However I am able to upload same iso via GUI. which tells me that it’s not connection issue. Must be something related to upload big file using ansible over vpn and wireless connection.
any idea what tunning do I need to do to make it work using ansible?
Hello Ankur,
The first thing I would do is enable debug mode in ansible.
More specifically, I might try is adding a timeout to your ucs upload and ucs install plays. This would let you know if your ucs plays are actually failing or if they’re installing the config like it seems on the big-ip.
I’d also throw a timeout on your config-sync play; if the ucs plays are actually working, then it seems like the playbook is actually hanging on the sync play, not the ucs plays.
That’s all I can think of for troubleshooting off the top of my head. Let me know if you figure it out!
best of luck,
Austin
