Issue Unix commands
How do we issue unix type commands while in the tmsh shell? We neeed to remove the mcpd.bin files so Big-IP recognizes new NICs on reboot. How do we “cd /var/db” and “rm /var/db/mcpd.bin”? Thanks!
We’re at Big-IP 11.3 running VE
As long as you aren’t using the “App Mode” license you can ssh into your F5 as the root user to get a “bash” shell. Once you log in you can navigate around the filesystem like you would on any other linux host.
Hi, this may offer some additional background:
Tried this and received the message “bash access has been disabled”
Guess we’re using “App mode” as root access has been disabled as well as going into the bash shell.
i do not think delete /var/db/mcpdb.* or touch /service/mcpd/forceload works in appliance mode.
there are two enhancement IDs for listing/renaming/removing file in appliance mode but /var/db and /service/mcpd are not in the directory list. i am not aware of other method. you may open a support case to see if they can add /var/db and/or /service/mcpd directory to those IDs.
ID425460 - Appliance Mode: Need a way to list, rename, and remove core files in TMSH
ID350895 - Appliance Mode: whitelist SCP directory access, whitelist (or disable) sftp access
hope this helps.
We´ll its been almost 6 years but this may be useful for someone:
I had same issue and noticed that my license summary has an entry that says:
Local Traffic Manager, i2800(Perpetual) (******-******)
App Mode (TMSH Only, No Root/Bash)
Since I installed that license i´m not able to issue tmsh commands
So I had to request a new license (fortunately this is a lab enviroment)
