Hi Another help =(, I have a pool of 6 members for 3389 service. The load balancing is round robin. All nodes are identical in CPU and RAM. But always one of them have more connections than of others. The ratio for all nodes is 1.
is it possible to try disabling cmp for the virtual server? sol14358: Overview of Clustered Multiprocessing (11.3.0 and later) 404 Page not found | BIG-IP Documentation
Disable CMP as nitass suggested. This worked for me. But if you are getting multiple requests on one connection then you can edit it in HTTP profile in requests per connection to 1.
