I first deploy a simple HTTP application using AS3 (with 2 pool members A and B) , then I make a change on GUI to delete a pool member B from the pool , then I make further change [PATCH] using as3, e.g. add a new pool member C to the pool. However, the last AS3 deployment will revert my change made on GUI (i.e. the deleted pool member will be added back and now there are 3 members (A+B+C) in the pool, but it supposes to be 2 members only (A and C) .
Is there any parameter/value I can set on AS3 body so that it will not revert the change I made on GUI?
So , it means that any changes made on the GUI wouldn’t affect the data/ array of AS3 template (i.e. if we update pool configurations on GUI, we must also update the config via AS3 as well )?
