Hi Folks,
I am facing an issue while uploading ISO file to LTM 1600."Its not Visible on GUI".I have checked at CLI its present there but unable to load/install it.Please someone suggest what’s the matter here.I have upload the file using winscp and GUI both.
What does ‘tmsh list /sys software image’ shows? You could upgrade to a newer version using the CLI. Maybe the newer version fixes the issue you are facing.
Thanks for replying…
IT shows the previous uploaded images…but not showing the new uploaded image which is latest and i wish to install.
And what shows the command ‘ls -la /shared/images/’? Are user, group and permissions consistent? What about the size of the images?
[root@bigip:Active:Standalone] config # ls -lha /shared/images/
total 2.2G
drwxrwxr-x. 3 root tomcat 4.0K Mar 17 10:46 .
drwxr-xr-x. 39 root root 4.0K Mar 24 12:46 ..
-rw-r--r--. 1 tomcat tomcat 2.2G Mar 17 10:45 BIGIP-14.1.4-0.0.11.iso
drwxr-xr-x. 2 root root 4.0K Apr 24 2020 tmp
Is there enough diskspace? Try ‘df -h /shared/images/’
[root@bigip:Active:Standalone] images # df -h /shared/images/
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg--db--vda-dat.share 15G 2.7G 12G 20% /shared
Not sure if your version also uses SELINUX. Try ‘ls -laZ /shared/images/’. Check SELINUX permissions.
[root@bigip:Active:Standalone] images # ls -laZ /shared/images/
drwxrwxr-x. root tomcat system_u:object_r:default_t:s0 .
drwxr-xr-x. root root system_u:object_r:default_t:s0 ..
-rw-r--r--. tomcat tomcat system_u:object_r:default_t:s0 BIGIP-14.1.4-0.0.11.iso
drwxr-xr-x. root root system_u:object_r:default_t:s0 tmp
/dev/mapper/vg--db--sda-dat.share.1
30G 6.6G 22G 24% /shared
ls -ltr /shared/images/
total 6513500
-rw-r--r-- 1 root root 798744576 Jul 18 2013 BIGIP-10.2.1.297.0.iso
-rw-r--r-- 1 tomcat tomcat 1379663872 Aug 18 2013 BIGIP-11.3.0.2806.0.iso
-rw-r--r-- 1 root webusers 1932533760 Mar 25 09:51 BIGIP-11.6.5.3-0.0.2.iso
-rw-r--r-- 1 root webusers 59 Mar 25 09:51 BIGIP-11.6.5.3-0.0.2.iso.md5
NOw let me explain my query again…above versions are visible on GUI i can see these image on GUI thus can istall too…but BIGIP-11.6.5.3-0.0.2.iso is not visible on GUI.
Try changing the ownership to tomcat. ‘chown tomcat:tomcat BIGIP-11.6.5.3-0.0.2.iso’. And remove the .md5 file.
