Is there any way to close the connection of iControl.Interfaces
Hi All,
I am using iControl java API to interact with the F5 BIG-IP LTM device. Here is the code below I am using to connect the device.
public iControl.Interfaces m_interfaces = new iControl.Interfaces(); boolean bInit = m_interfaces.initialize(hostname/IP, user_name, pass_word);
Once the m_interfaces.initialize(, , ) creates the connection and after my operations performed, is there any way to close the connection. If there any number limit that BIG-IP LTM will allow to create the sessions. If so what is the number.
Thanks in advance.
Regards, PRakash.K
