I am thinking about setting up a vip ldaps://ldap.domainname.com:636 that will use different backend ldap server instances depending on the “ou”. Are there any builtin iRules to assist?
-Brian
-Brian
There aren’t currently any built in LDAP inspectors as far as I’m aware. You should, however, be able to use normal TCP inspectors to break down the traffic and search for the desired data.
-Colin
Is there any plans to include such functionality in the future?
Thanks,
Brian
This type of question is usually best directed at Technical Support, as they can often times get more information about the product roadmap and see if there is any public information that they can share regarding the questions you have.
-Colin
