Here’s the issue. I have a pool of web servers and a pool of app servers that are being load balanced by a BigIP. The customer would like when the number of connections to the web pool compared to the number of connections to the app pool reaches a ratio greater than 50:1 to bascially redirect the end user to a static web page saying that the site is too busy. Can this be done with an irule? Any help on how to do this would be greatly appreciated.
One approach you could take would be to count current connections for both virtuals, populating global variables or a statistics profile for each connection count, and comparing when a new client connects.
We don’t currently support floating point calculations, so you may need to use the int() function to find your ratio…
HTH
/deb
