Hi all,
I have a new single link ISP connection into my F5 (active, passive) as shown in below diagram.
The connection between the ISP router and my F5 unit is a /30 network (.211 use by ISP router and .222 to be use by F5).
q1) In this case, can I just create a floating self-ip (.222) so that in the event that node1 go down, the self-ip can still failover / float to node2 ?
q2) what would be the need of a static self-ip for such setup above ?
Hope some gurus here can point me in the right direction.
Thank you.
Why not use one internal subnet for point to point connection from your ISP router to your BigIPs? I.e. Network 192.168.0.0/24 can operate in place of 118.201.75.220/30 and you will not miss out on anything, unless you have a valid reason to maintain full BGP routing table in that BigIP cluster. Basically your ISP is wasting 3 usable public IP addresses to allocate you one useful address. You could potentially cut your ISP costs if you asked for a single routed IP solution instead of current proposal.
If you want to go with what is on the network diagram - you do need a local-only SelfIP on each unit. It’s a pre-requisite to configure Floating SelfIP. BUT there’s no significance for device operation if you populate these local-only SelfIPs with IP addresses that your ISP will not route in the Internet for you. So you can populate your BigIP 01 local-only SelfIP with 118.201.75.217/29 and BigIP 02 local-only SelfIP with 118.201.75.218/29. Confirm this wish with your ISP.
Hi Hannes,
Thanks for your reply.
The segment right now between the ISP and F5 is a /30 network namely 118.201.75.221 and 118.201.75.222
I understand I will need to create a static self-ip before creating a floating one.
Can I somehow “trick” F5 by creating a static self-ip .e.g 118.201.75.220/29 but in actual fact this IP/29 was not assigned by the ISP to us. (we are only allocated a /30)
Since the ISP is routing to us using the .222/30 IP as its next hop, and i have configured .222 as a floating IP, communication from and to device will use .222/30 IP which is valid.
Will there be any implication then since the “fake” static self-ip (118.201.75.220/29 in this case) is never actually in use ?
Regards,
Noob
Hi Hannes,
Regards,
Noob
Since you didn’t confirm the need for full BGP table, my first recommendation is still to scrap that /30 network and build something that is nice to look at.
I’m not entirely sure on the implications of using network address .220/30 or broadcast address .223/30 as host addresses without seeing full interface configuration in that ISP router (or router cluster?). In some cases it is possible to violate network sub-netting standards and get away with it. Nowadays even /31 point to point links are used in production with a bit of trickery. However, there are a strict set of criteria for this to work. Inform your ISP about your addressing plans, and then test this. 10 Minute maintenance or downtime window should suffice here.
