Hi everybody
I’ve some question about SSL profile.
Is !SSLv3 specify in cipher suite the same as “No SSLv3” option in SSL option?
Thank you very much
Hi everybody
Thank you very much
Yes, It is equivalent.
use :
ALL:!SSLv2!SSLv3
and also disable weak ciphers.
No it is not!
!SSLv3 hard disables the SSLv3 ciphers. No SSLv3 disables the SSLv3 protocol.
If you set !SSLv3, but not No SSLv3, the client may negotiate SSLv3 as protocol, then not be able to use any ciphers, since you have disabled them!
See here for reference: Cipher Suite Practices and Pitfalls
No it is not!
this one deserves a few upvotes to make sure it is on top.
