This Irule allow you to detect the number of remaining servers up
when CLIENT_ACCEPTED {
Check if the VS default pool has no active members
if {[active_members [LB::server pool]] == 1}{
# redirect to a sorry page
pool sorry_pool
I hope I have correctly understood your request. it’s the notion of a site that I have not really understood, but if you give me more details I could sketch out my explanation.
It are actually 2 datacenters (sites). The applications are cassandra database based. So as soon as 2 cassandra nodes drop, I lose consistency and the last surviving node in that site cannot handle any writes.
However, the 2 sites are in terms of speed equal with high bandwidth in between, hence the balancing over all nodes with 1 entry point, as if both sites were just 1 big application.
i was told that was not possible in active/active. So wanted to double check.
Not sure why you redirect to a sorry page. I actually want to continue processing in the other site.
So :
1 dns name, 6 nodes
2 sites, each 3 nodes
service should ALWAYS be running
if 1 node fails, it gets excluded from the pool, both sites continue to process
if 2 nodes fail within the same site, that entire site is excluded from the pool, leaving the other site to continue handling the requests
Unless the 2 sites fail with 2 nodes each, I should never get a 500 error.
