Is it possible to write iRule to run external script when F5 change node selection with priority ?
I have a requirement to load balance two servers in Active/Standby mode using minimum active member and priority settings. When the primary server goes down and F5 direct traffic to secondary server, is it possible to write iRule to run an external script to do something (run remote script) ? Is there any event trigger that I can write such rules ?
