is it possible to write a custom http header authentication module? like check a cypto signature and expiration date?
Is it possible to write a custom http header authentication module? If a certain header exists, I’d like to check a cryptographic signature on it and then verify the header hasn’t expired.
Is there an API or programming language available to implement such a thing on F5 devices?
Well, yes of course. There’s not much you really can’t do with iRules (the F5 programmability API), so such a thing would be extremely reasonable.
    if { [HTTP::header exists MYAUTHHDR] } {
         do something with that header
The real question, however, is how you would implement such a thing securely. HTTP headers don’t usually provide any sort of challenge-response mechanism, so you’d have to create such a thing, both in iRules AND within the client from scratch, and you’d have to make sure that a) the communication was encrypted, and b) that it is (hopefully) not spoofable.
Better not to re-invent the wheel, especially when it comes to security. Is there any reason you can’t use HTTP Basic auth or Client Certificate auth, to name a few examples?
