Guys, I have a need to write up an irule that will be able to receive any DNS requests and always respond with the same IP address. ( The function is designed to work with a HTTP redirect function to redirect customers to an error page.).
Is this possible ? Could you provide a basic example?
Thanks in advance
Ian Lohning +61 (0)419 561 774
Check out this page, it has examples: DevCentral
There are easier ways to redirect to an error page:
1) Fallback URL in the HTTP profile.
2) Priority groups
3) HTTP::redirect http://1.2.3.4/Sorry.html
Thank you for your response, but it would be appreciated if you could address the question before providing alternative solutions.
Is it possible to write an irule that will be able to receive any DNS requests and always respond with the same IP address? Could you provide a basic example?
Thanks in advance Ian Lohning +61 (0)419 561 774
I did address the question before I provided alternatives.
You missed this line:
Check out this page, it has examples: DevCentral - An F5 Technical Community
Check out the link, there are examples. On an LTM you will need a DNS services license. On a GTM you are good to go.
Here is one of the examples:
Send one or more IP addresses for a response to an A query
Use on an LTM virtual server with a DNS profile enabled
when DNS_REQUEST {
Log query details
log local0. "\[DNS::question name\]: [DNS::question name],\
\[DNS::question class\]: [DNS::question class],
\[DNS::question type\]: [DNS::question type]"
Generate an answer with two A records
DNS::answer insert "[DNS::question name]. 111 [DNS::question class] [DNS::question type] 1.1.1.1"
DNS::answer insert "[DNS::question name]. 111 [DNS::question class] [DNS::question type] 1.1.1.2"
Stop further processing of the query after this iRule and send the answer to the client
DNS::return
HTH
