Is it possible to use an iRule to read from and return the F5's log files?
I am currently in the process of creating an iRule which returns a debug page for our virtual servers. When a user connects to the iRule returns a custom page with various statistics about the connection. For example, I’m getting the client IP address using the IP::local_addr command.
Along with these statistics, I am wanting to include a snippet of the logs from the F5. In particular, I am interested in the LTM logs and ASM logs. Is this possible to read these logs using iRules?
Hi Samyool,
you can’t read locally stored file streams using iRules. The required TCL commands to open and read such are disabled by the developers.
The only chance I see for you, is to open a [SIDEBAND] connection to the REST-API, execute a tail /var/log/ltm command via the /mgmt/tm/util/bash endpoint, parse the REST response and finally display the output on your debugging page.
API Request:
POST /mgmt/tm/util/bash HTTP/1.1
Host: yourbox.domain.de
Content-Type: application/json
Authorization: Basic YourBase64Creds
content-length: 56
Connection: close
{"command":"run","utilCmdArgs":"-c 'tail -n 50 /var/log/ltm'"}
Note: Let me know if you need further assitence to implement such a [SIDEBAND] connection to query REST within iRules.
Cheers, Kai
Hi Samyool,
I’ve recycled some older code for you to get a PoC up and running within a few minutes. Here we go…
Configure a Layer4 VS:80 that points to the MGMT-ETH:443 of your F5
1.) Execute the following command on TMSH
load sys config merge from-terminal
2.) Paste the following config into TMSH
ltm pool Pool_F5-MGMT-ETH {
    members {
        Node_F5-MGMT-ETH:https {
            address x.x.x.x%1
            session monitor-enabled
            state up
    monitor gateway_icmp
ltm virtual VS_F5-MGMT-ETH {
    destination 1.1.1.1%1:http
    ip-protocol tcp
    mask 255.255.255.255
    profiles {
        serverssl {
            context serverside
        tcp { }
    source 0.0.0.0%1/0
    source-address-translation {
        type automap
    translate-address enabled
    translate-port enabled
Note: You have to change the node IP address to match the MGMT-IP of your LTM. The IP of the Virtual Server can be keept, since its just used for internal communication.
3.) Hit CRTL+D to save the config change
Write a TCL procedure to trigger a SIDEBAND connection towards your Layer4 VS:80 (aka. your REST-API) to execute [tail] and finally download X lines of logfile Y.
1.) Add the following procedure to your existing iRule
proc get_logfiles { virtual basic_creds logfile lines } {
    set tcp_conn [connect -timeout 2000 -idle 2000 -status tcp_conn_status $virtual]
    if { $tcp_conn_status equals "connected" } then {
        set http_request_body "\{\"command\":\"run\",\"utilCmdArgs\":\"-c 'tail -n $lines $logfile'\"\}"
        set http_request "POST /mgmt/tm/util/bash HTTP/1.0\r\nAuthorization: Basic $basic_creds\r\nContent-Length: [string length $http_request_body]\r\n\r\n$http_request_body"
        send -timeout 2000 -status tcp_sent_status $tcp_conn $http_request
        if { $tcp_sent_status equals "sent" } then {
            set http_response [recv -timeout 5000 $tcp_conn]
            if { $http_response starts_with "HTTP/1.1 200" } then {
                return [getfield $http_response {commandResult":"} 2]
            } elseif { $http_response equals "" } then {
                return "Error: Receive Timeout"
                return "Error: API Response = $http_response"
            return "Error: Send Status = $tcp_sent_status"
        return "Error: Connection Status = $tcp_conn_status"
Call the TCL procedure within your iRule
set log_lines [call YOUR_IRULE_NAME::get_logfiles "VS_F5-MGMT-ETH" [b64encode "admin:password"] "/var/log/ltm" 50]
Cheers, Kai
