Hello,
Just like the titles says I am trying to determine if
1 : Can I upgrade my existing 11.3 LTM VE instances from 200mbps to 1gbps without having to re-deploy the entire VM (I know newer versions are available but code-locked to 11.3 for other reasons).
2 : Will the fact that my new license is from a different sku make a difference.
I have several 11.3 VE LTM instances in the field running with 200mbps licenses from 2014. I’ve recently acquired 1gbps licenses with sku : F5-BIG-LTM-VE-1G-V13. I’ve read what licensing info I could find but could not locate any existing process for replacing or upgrading an existing license for a production VE instance.
Links I’ve reviewed :
(EOL announcement for older versions and replacement skus).
404 Page not found | BIG-IP Documentation DevCentral - An F5 Technical Community 404 Page not found | BIG-IP Documentation 404 Page not found | BIG-IP Documentation 404 Page not found | BIG-IP Documentation
