I wondered if it would be possible to specify geolocations that do not influence automatic learning?
For example, we have an application that should only be used from certain countries and, therefore, traffic from other locations is not useful for traffic learning.
Thanks in advance and regards,
Daniel
You should be able to add an IP address exception for a specific IP or a range. Go to Security ›› Application Security : IP Addresses : IP Address Exceptions. After you add an IP address/range, there is a checkbox which will allow you to Ignore in Learning Suggestions.
If I understand your question, then there is no way to turn off learning for a geolocation in the GUI.
