Is it possible to create an client-ssl profile with client authentication using tmsh?
I don’t see flags available for setting up the client authentication options through tmsh on initial creation. Is there a way to do this?
create ltm profile client-ssl NAME-OF-PROFILE cert NAME-OF-CERT key NAME-OF-KEY defaults-from clientssl
That is what I have so far, but I don’t see any available options from the syntax help. Any ideas?
Hi Warren, Hope this helps:
create ltm profile client-ssl myclient peer-cert-mode ?
Values:
  ignore
  request
  require
http://support.f5.com/kb/en-us/solutions/public/14000/400/sol14499.html?sr=34533077
Kevin
That is 100% perfect. Thank you. My bad for not cluing-in that “peer-cert-mode” in tmsh equals “Client Certificate” in the GUI. Thank you very much!!!
Welcome Warren, glad that was helpful!
