I have 2x VIP - one SSL terminated and the other not. The iRule is the same for both VIP - all traffic that is dest’d to the non-SSL VIP works - SSL nada
if { [HTTP::method] ne “POST” } {
event disable all
return
if { (not [HTTP::header exists “Content-Length”]) or ([HTTP::header “Transfer-Encoding”] contains “chunked”) } {
event HTTP_REQUEST disable
event HTTP_REQUEST_DATA disable
event HTTP_RESPONSE disable
set http_request_time [clock clicks -milliseconds]
set uri [HTTP::uri]
HTTP::collect [HTTP::header Content-Length]
when HTTP_REQUEST_DATA {
if { [HTTP::uri] contains “csp-authentication” } {
set id [findstr [HTTP::payload] “systemId>” 9 " if {$id contains “IVR”} {
set call [string trim [findstr [HTTP::payload] “” 20 “xmlns=”]]
set output “CALL=$call SYSID=$id”
} elseif {$id contains “MYCRICKET”} {
set call [findstr [HTTP::payload] " set output “CALL=$call SYSID=$id”
set output “SYSID=$id”
} elseif { [HTTP::uri] contains “csp-apl” } {
if { [matchclass [IP::client_addr] equals $::net_internal] }{
set tmp [findstr [HTTP::payload] “<” 16 “:”]
if {$tmp contains “ns1”} {
set call [findstr [HTTP::payload] " set output “CALL=$call”
} elseif {$tmp contains “ns0”} {
set call [findstr [HTTP::payload] " } else {
set output “CALL=UNKNOWN”
set tmp [findstr [HTTP::payload] “” 21 “>”]
set tmp [findstr [string map {" " “” “\n” “”} [HTTP::payload]] “” 21 “>”]
set output “CALL=$tmp”
HTTP::release
when HTTP_RESPONSE {
set response “POOL=[LB::server pool] NODE=[LB::server addr] STATUS=[HTTP::status] RESPONSETIME=[expr [clock clicks -milliseconds] - $http_request_time]”
when CLIENT_CLOSED {
if { [info exists output] and [info exists response] } { log -noname 10.66.48.45:514 local0.warning “DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=[IP::client_addr] DST=[IP::local_addr] URI=$uri $output $response” }
Here is a sample of working output
Sep 27 13:25:19 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=TCP SRC=208.45.140.93 SRCPORT=40257 DST=10.12.0.101 DSTPORT=443 OPEN=92502
Sep 27 13:25:19 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=208.45.140.93 DST=10.12.0.101 URI=/csp-apl/APL CALL= POOL=sandapcspapl-80 NODE=10.12.18.18 STATUS=500 RESPONSETIME=387
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=TCP SRC=199.38.44.8 SRCPORT=53430 DST=10.12.0.101 DSTPORT=80 OPEN=614
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=199.38.44.8 DST=10.12.0.101 URI=/csp-apl/APL CALL=getCustomerInformation POOL=sandapcspapl-80 NODE=10.12.18.16 STATUS=200 RESPONSETIME=416
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=TCP SRC=199.38.44.8 SRCPORT=52511 DST=10.12.0.101 DSTPORT=80 OPEN=181
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=199.38.44.8 DST=10.12.0.101 URI=/csp-authentication/CSPAuthenticate CALL=createSession SYSID=IVR POOL=sandapcspapl-80 NODE=10.12.18.17 STATUS=200 RESPONSETIME=31
