Is it possible to capture packets like tcpdump on F5 Load balancer?
What OS is installed on a F5 Load Balancer? And is it possible to capture tcpdump on the Loadbalancer to capture packets to verify if a connection is getting dropped at LB Level?
Did you at least search in a search engine???
In google, search “f5 tcpdump” first answer leads to this article:
Hey Raj
The BIG-IP’s operating system is based upon Red Hat and yeah you can use tcpdump to troubleshoot load balancing issues. Please check this article for reference:
K411: Overview of packet tracing with the tcpdump utility
yes. you can capture with tcpdump.
