I am trying to combine two irules together and having no luck. Can someone help ? The details are as follows: One rule is for http to https redirect while the second irule is for fallback page to be displayed if the original web page goes down. 1) http to https redirect when HTTP_REQUEST { string tolower [HTTP::host] if {[HTTP::host] contains “maximoqa.cenovus.com” }{ HTTP::redirect https://[HTTP::host]/maximo/ } else { HTTP::redirect https://[HTTP::host].cenovus.com/maximo/ } }
2) Use the LTM as a webserver as a lite version of a maintenance page. Like a fallback page when HTTP_REQUEST {
sets the timer to return client to host URL set stime 10
Use the Host header value for the responses if it’s set. If not, use the VIP address. if {[string length [HTTP::host]]}{ set host [HTTP::host] } else { set host [IP::local_addr] }
Check if the URI is /maintenance switch [HTTP::uri] { “/maintenance” {
Send an HTTP 200 response with a Javascript meta-refresh pointing to the host using a refresh time
HTTP::respond 200 content \
"Maintenance page \
Sorry! This site is down for maintenance.
" “Content-Type” “text/html” return } } If the pool_testLB is down, redirect to the maintenance page if { [active_members pool_testLB] < 1 } { HTTP::redirect “http://$host/maintenance” return } }
As long as you’re doing SSL Offload (Or re-encryption), then you can put an iRule on that will respond to the HTTP requests (The SSLCLient Profile is needed to decrypt & encrypt the stream between the BigIP and the client).
Or were you asking about the iRUle for the HTTP to https? (That’s a built-in iRule BTW in 11.something onwards).
Can you clarify a bit, your heading is a little contrary to what you wrote up.. Sounds like you just want to redirect users to the secure site, and also serve up a maintenance page, but when do you want to serve up the maintenance page? when no pool members are available?
Yes it’s absolutely possible.. you’ll need two different Virtual servers, one listening on 80 one listening on 443.. the 80 vs doesn’t need anything attached to it, just the http 2 https irule. As Hamish mentioned, you will need to terminate SSL on the 443 VIP to do the more involved irule..
Hi, I want the serve up the maintenance page when no pool members are available ? Since we already have http to https redirect irule attached to the port 80 virtual server, I don’t know how to combine the two irules into one.
Will I be able to make it work by attaching a seperat maintenance page irule to the port 443 virtual server ?
You wouldn’t combine iRules. Have your HTTP to HTTPS redirect rule on your 80 virtual server. The maintenance page will only work if you are terminating SSL on the 443 virtual server. If so, then you could either use an iRule or configure a fallback host in your HTTP profile.
I currently have the http-to-https irule attached to the port 80 VIP and it works perfectly. I have a second irule attached to the HTTPS VIP but it does not work.
Below is the irule : when HTTP_REQUEST {
"Maintenance page \
Kareem, do you have a client SSL profile applied to your 443 virtual server? If not, then your iRule will not work. Can you please post your 443 virtual server config?
maximo_qa_redirect_vs - this is the port 80 VIP maximo_qa_redirect - this is th HTTP-to-HTTPS redirct irule maximo_qa_vs - this is the port 444 VIP ( there is SSL client profile attached ) maximo_qa_pool( 5 members in the pool on various ports ) No SSL encryption on the back end between the F5 and servers.
yes I do have an HTTP Profile attached to the port 443 VIP and I want to Use the LTM as a webserver as a lite version of a maintenance page. In this case, it returns a maintenance page with text to return when the pool members are not available. Also refreshes the client’s browser, every x seconds, returning back to the site, in case the site returns to normal after an outage or maintenance.
Are you thinking about using the Fallback host option under the HTTP profile ? Will that present the maintenace page or it will just redirect users to another server that has the page ?
You are using a switch in your iRule, but you are only matching against one argument. Check out this post. Nitass included a good example in this thread that you should be able to use:
Is it possible to create a very simple irule that will present a maintenace page and attach it to the port 443 VIP while the othe irule for HTTP-to-HTTPS redirect is still attached to the port 80 VIP ?
Yes. Leave your HTTP to HTTPS redirect iRule on your port 80 virtual server. Then this can be your iRule for your 443 virtual server:
when RULE_INIT {
set static::maint_page "Sorry! This site is down for maintenance."
set maint_prefix "/maintenance.html"
if { [HTTP::uri] equals "$maint_prefix" } {
HTTP::respond 200 content $static::maint_page "Content-Type" "text/html" "Connection" "Close"
return
if { [active_members [LB::server pool]] < 1 } {
HTTP::redirect $maint_prefix
