Hi, Is iControl 11.1.0 SDK compatible with 10.x versions ? I am sure that it will be compatible with any newer version of BIG-IP as this the latest SDK available.
Thanks, Raghu
Thanks, Raghu
There may be interfaces/methods introduces in 11.1 that will not work with 10.x, and it’s possible there are interfaces/methods not shown in the 11.1 SDK that will work with 10.x. With those caveats, yes, it should work fine.
