Hello,
We have a large F5 deployment, and I inherited this project. Working to learn my way around F5.
That said, I have a request to create 2 VIP’s. Easy. But they want 1 VIP per data center. Again easy. They want this to be internally accessible only (so no external NAT) and want it so that if Data center 1 goes offline, the VIP in Data Center 2 picks up and begins load balancing the traffic.
I believe GTM is the way to go, but not really sure how to accomplish this ask. Could anyone please point me in the right direction?
Thank you
Greetings, This sounds very much like something GTM (now DNS) could handle. DNS’ specialty is steering traffic by resolving DNS queries using a Wide-IP.
Wide-IPs are made up of pools that are made up of virtual servers. Wide-IPs also use load balancing algorithms to determine which pool to use.
So, in the case you describe, it sounds like your VIP failover configuration might resemble:
Wide-IP (www.example.com)
+--+----Pool_1 = 1.1.1.1 (data center 1)
+------------Pool_2 = 2.2.2.2 (data center 2)
You would select global availability as the wide-ip load balancing algorithm which essentially says; hand out IP addresses (1.1.1.1) from Pool_1, until it becomes unavailable, then use Pool_2 IP address (2.2.2.2).
DNS also has topology based load balancing, so, hand out IP 1.1.1.1 if a query comes from this 10.10.10.1 and 2.2.2.2 if a query comes from 20.20.20.2.
Here’s a very good introduction on the topic:
