Is APM the firepass replacement?
If so, will Linux guests be able to VPN connect?
Hi Joseph,
Yes APM has effectively been adopted as the FirePass replacement.
Please see this support article with specific client functionality:
Hi Joseph,
Thank you
Thank you
it is with some exceptions, be sure to clearly detail what you use your firepass for before you get into APM.
for example web access to file shares is missing.
