Currently, I’m having to manually update certs on our F5 and I’m wondering what other people are using to automate this. We use Sectigo which supports the Certbot F5 plugin, but a fellow tech that tested it said it doesn’t work when a vserver has more than one SSL profile assigned.
Is anyone using the Certbot tool? If not, what tool are you using? I like to be able to automate this (and be confident it “just works”).
zone _tls.example.com only has NS records pointing to locally hosted NS servers and is NOT replicated to DNS secondaries. TTL is set very low (300 seconds).
certbot out of the box documents this type of CNAME setup, but does NOT implement it in the rfc2136 module. My fork has this updated from hpa’s original patch.
the existing certbot-bigip creates multiple certs on the f5s for SAN certs. This means a “wildcard” cert creates both of these:
example_org_Letsencrypt
wildcard_example_org_Letsencrypt
where BOTH of these certs are the same cert supporting both names. This is a Bad Thing. the first would be enough. Also, we strongly prefer lowercase names, so "L"etsencrypt is a Bad Name. Also, rfc2136 can be used for multiple providers, not just letsencrypt. I’d prefer and uploaded cert with this naming:
auto_example.org
Let’s Encrypt should support multiple wildcards in the same cert. So potentially I could have one cert covering:
Some new features and fixes are already implemented there. Watch out for some breaking changes due to the renaming of the certbot plugin names and the python module for installation.
As we use the plugin for our selves and for some customers, I also started to create an Ansible playbook as a wrapper to manage and maintain the domains. It’s still new and in an early state… Erich Malzer / certbot-ansible · GitLab
And I plan to take a look at creating two other plugins like `certbot-f5next` and `certbot-f5xc` to also be able to use NEXT and XC!
