iRules with subnet failed.
Hi,I met a problem with iRules recently, below is our iRules:
if { [IP::addr [IP::remote_addr] equals 221.177.152.0/26] } {
pool CMNET }
else { pool CMWAP_ OTHER }}
if the DNS query client with IP address 221.177.152.33 send a DNS message, f5 will answer with pool CMWAP_OTHER.
and if we change the iRules to below, the answer will be correct with pool CMNET.
if { [IP::addr [IP::remote_addr] equals 221.177.152.33/32] } {
pool CMNET }
else {
pool CMWAP_ OTHER
so , what’s the difference between a host and a subnet int iRules?
thanks
I dont think we can use the euqals command for the IP range subnet…Try with using the below if statement. This may not be correct but i think we cannot use equals for a range of IPs since the equals to operator checks for the exact match only…
if{ [221.177.152.0< IP::addr[IP::remote_addr] ] & [IP::addr[IP::remote_addr]<=221.177.152.63]}{
pool CMNET
else..
good idear!!!
but, below sentence was copied from DevCentral Wiki, the descripion of IP::addr:
To perform comparison of client-side IP address with subnet 10.0.0.0. (Will return 1 or 0, depending on client IP address.)
view sourceprint?1 [IP::addr [IP::client_addr] equals 10.0.0.0/8]
got wrong message with operator “<”
line 2: [undefined procedure: 221.177.152.0] [221.177.152.0 < IP::addr [ IP::remote_addr ] ]
line 2: [invalid option “<” must be: equals mask parse] [IP::addr [ IP::remote_addr ] < 221.177.152.63 ]
seems the only opreator is “equals”
Syntax¶
1 IP::addr [/] equals [/]
2 IP::addr parse [-swap] []
3
4 v11 Additions/Changes:
5 IP::addr parse [-ipv6|-ipv4 [-swap]] []
IP::addr [IP::remote_addr] equals 221.177.152.0/26 should be correct.
how do you know if traffic is sent to wrong pool? can you make some log in event such as SERVER_CONNECTED?
my device is GTM 3900, and I can use “nslookup” to check the DNS query answer results from different pools.
this means different pools return different DNS answers.
In my case, IP::addr [IP::remote_addr] equals 221.177.152.0/26 will never match the DNS query host IP address, but 221.177.152.33/32 will be correct, do I need some licence or have some special settings in the system?
You don’t need to use /32 as it’s implicit when you use a host address with IP::addr:
if { [IP::addr [IP::remote_addr] equals 221.177.152.33] } {
Aaron
now the problem is:
1. [IP::addr [IP::remote_addr] equals 221.177.152.33/32] works fine.
2. [IP::addr [IP::remote_addr] equals 221.177.152.0/26] never match the source clients.
221.177.152.0/26 should match 221.177.152.0 - 221.177.152.63. Can you try logging the client IP to verify what you’re getting for [IP::remote_addr]?
Here’s a v11 rule you can use to confirm this:
when RULE_INIT {
for {set i 0}{$i <=63}{incr i}{
log local0. "\[IP::addr 221.177.152.$i equals 221.177.152.0/26\]: [IP::addr 221.177.152.$i equals 221.177.152.0/26]"
[IP::addr 221.177.152.0 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.1 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.2 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.3 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.4 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.5 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.6 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.7 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.8 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.9 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.10 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.11 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.12 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.13 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.14 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.15 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.16 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.17 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.18 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.19 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.20 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.21 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.22 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.23 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.24 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.25 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.26 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.27 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.28 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.29 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.30 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.31 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.32 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.33 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.34 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.35 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.36 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.37 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.38 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.39 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.40 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.41 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.42 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.43 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.44 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.45 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.46 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.47 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.48 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.49 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.50 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.51 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.52 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.53 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.54 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.55 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.56 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.57 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.58 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.59 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.60 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.61 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.62 equals 221.177.152.0/26]: 1
[IP::addr 221.177.152.63 equals 221.177.152.0/26]: 1
Aaron
Thanks for your kindly support.
here is my iRules:
when DNS_REQUEST {
if { [IP::addr [IP::remote_addr] equals 10.97.188.0/24] } {
log local0. “[IP::remote_addr] equals 10.97.188.0/24 Correct!!! : [IP::addr [IP::remote_addr] equals 10.97.188.0/24]”
else {
log local0. “[IP::remote_addr] equals 10.97.188.0/24 Error!!! : [IP::addr [IP::remote_addr] equals 10.97.188.0/24]”
and got log with ERROR:
Rule HN_GGSN_Pool_rules: 10.97.188.124 equals 10.97.188.0/24 Error!!! : 0
this can make sure [IP::addr 10.97.188.124 equals 10.97.188.0/24] returns 0, that’s joke?
very strange, this format will work fine:
if { [IP::addr [IP::remote_addr]/26 equals 221.177.152.0] }
what version are you on? That doesn’t look right at all. BTW, the comparison should be last for the most efficient operation, though in your case, it doesn’t appear to be working. Here’s an article I wrote on the various methods for comparing IP addresses:
Click Here
my version: BIGIP-10.2.1.297.0.iso
I don’t think this is a good methord to compare also, but it is the only way can work.
and after I read your article then change to this statement.
