The above is a variation of our usual rule for content directing , the problem with the above is that it appears any uri’s which have a “fullstop” in dont’ work.
So */dev-pool* works fine , but /dev.inbound.prod.Portal* doesn’t , if we change “.” to be “-” this works.
Unfortunatley the website we wish to apply this to, we cannot change…
That’s really odd. switch -glob should use the same logic as ‘string match’. I don’t think the period has any significance as a wildcard for string matching:
