Hello,
We are working with a search engine that is sending HTTP queries to its search engines via HTTP POST requests. I need to setup an irule that has to do URI mapping based on some HTTP parameters sent via this POST requests. Because it’s a POST and not a GET request, I can’t user HTTP::uri to analyze the parameters and do the URI mapping to forward the HTTP request to the correct pool.
The following irule is working with HTTP GET but not HTTP POST. Do you have any idea how to convert this irule to be compliant with a POST request ? Thanks in advance for any support.
JC
set DEBUG 0
Workaround: BIG IP Cache limitation for huge URI
if { [string length [HTTP::uri]] >= 16384} {
WAM::disable
set uri [string tolower [HTTP::uri]]
Rewrite only URI starting with /action= or /?action=
if { $uri contains "action=" } {
URI::query works only if the Query String starts with a '?'
so we add a ? in front of the Query String if needed
if { not ([HTTP::uri] starts_with "/?") } {
set uri [string replace $uri 0 0 "?"]
Extract from URI the value of the following parameters:
MatchLanguage
action
DatabaseMatch
set matchlanguage_value [URI::query $uri matchlanguage]
set action_value [URI::query $uri action]
set db_value [URI::query $uri databasematch]
if { $DEBUG > 0 } {
log local0. "MatchLanguage value=$matchlanguage_value"
log local0. "Action value=$action_value"
log local0. "DatabaseMatch value=$db_value"
Rewrite URI for content servers only for the 3 types of actions otherwise default to proxy:
getquerytagvalues
query
termexpand
if { $action_value eq "getquerytagvalues" or $action_value eq "query" or $action_value eq "termexpand" } {
Remember original URI before rewriting
to keep the ability to do a rollback in case we will find an "unknown" language
set original_query [HTTP::uri]
set uri [HTTP::uri]
Rewrite URI : replace .._Elx with Elx where .. match 2 chars
regsub -all ".._Elx" $uri "Elx" uri
HTTP::uri $uri
if { $DEBUG > 1 } {
log local0. "Before URI rewrite : $original_query"
log local0. "After URI rewrite : $uri"
Depending on MatchLanguage parameter found in the URL
Select the corresponding pool in charge of the language
If language is not in the lits, rollback to original URI and
send the query to the IDOL proxies
switch $matchlanguage_value {
"english" { set selected_pool "idol-en-content-test-pool1" }
"french" { set selected_pool "idol-fr-content-test-pool1" }
"german" { set selected_pool "idol-de-content-test-pool1" }
"czech" { set selected_pool "idol-cs-content-test-pool1" }
"bulgarian" { set selected_pool "idol-bg-content-test-pool1" }
"croatian" { set selected_pool "idol-hr-content-test-pool1" }
"danish" { set selected_pool "idol-da-content-test-pool1" }
"dutch" { set selected_pool "idol-nl-content-test-pool1" }
"estonian" { set selected_pool "idol-et-content-test-pool1" }
"finnish" { set selected_pool "idol-fi-content-test-pool1" }
"gaelic" { set selected_pool "idol-ga-content-test-pool1" }
"greek" { set selected_pool "idol-el-content-test-pool1" }
"hungarian" { set selected_pool "idol-hu-content-test-pool1" }
"italian" { set selected_pool "idol-it-content-test-pool1" }
"latvian" { set selected_pool "idol-lv-content-test-pool1" }
"lithuanian" { set selected_pool "idol-lt-content-test-pool1" }
"maltese" { set selected_pool "idol-mt-content-test-pool1" }
"portuguese" { set selected_pool "idol-pt-content-test-pool1" }
"romanian" { set selected_pool "idol-ro-content-test-pool1" }
"slovak" { set selected_pool "idol-sk-content-test-pool1" }
"slovenian" { set selected_pool "idol-sl-content-test-pool1" }
"spanish" { set selected_pool "idol-es-content-test-pool1" }
"swedish" { set selected_pool "idol-sv-content-test-pool1" }
"norwegian" { set selected_pool "idol-no-content-test-pool1" }
"icelandic" { set selected_pool "idol-is-content-test-pool1" }
default {
if { $DEBUG > 0 } { log local0. "matchlanguage not found : roll back to idol-proxy-test-pool1" }
HTTP::uri $original_query
set selected_pool "idol-proxy-test-pool1"
if { $DEBUG > 0 } {
log local0. "Selected Pool=$selected_pool , MatchLanguage=$matchlanguage_value, Action=$action_value"
Send the HTTP request to the previously selected pool
pool $selected_pool
