I am terminating an SSL connection with a raw ASCII stream inside.
It’s for a proprietary protocol that is just ASCII over TCP that I have made the client send over SSL.
This all works fine with a client SSL profile assigned to the virtual server and no profile set on the server side.
But I have added an iRule to inspect the first packet and see if it contains a string I am expecting, but I only get the encrypted data !
If I try and use server side events I can only get the data coming back from the server and not what the client is sending.
Any ideas ?
Cheers,
Steve
Here’s my rule:
when CLIENT_ACCEPTED {
SSL::enable
when CLIENTSSL_HANDSHAKE {
log “SSL handshake ok”
TCP::collect
when CLIENT_DATA {
log “Client payload [TCP::payload]”
TCP::release
when SERVER_CONNECTED {
TCP::collect
when SERVER_DATA {
log “Server payload [TCP::payload]”
TCP::release
Example packet in the log looking encrypted:
: Client payload À-Â`ÃÃÃ)ð¶Â±¼`çÃÂRªúmÿsÂéq!ÃÂÂÃp\¤ …
