Hello everyone
I want to make an iRule which;
1) Select a pool by URI during first http request 2) For the subsequent requests for css and graphic files(with URI different than the first request), load balance by cookie.
What I got so far:
log -noname local0. "HTTP_REQUEST URI: [HTTP::uri]"
switch -glob [substr [ HTTP::uri ] 1]
"foo/*" { pool pool_foo
The server have all content in /
HTTP::uri [string map {"/foo/" "/"} [HTTP::uri]]
log -noname local0. "Selected pool_foo by URI"
"bar/*" {
pool pool_bar
HTTP::uri [string map {"/bar/" "/"} [HTTP::uri]]
log -noname local0. "Selected pool_bar by URI"
default {
switch -glob [HTTP::cookie names]
"*pool_foo" { pool pool_foo
log -noname local0. "Selected pool_foo by cookie"
"*pool_bar" { pool pool_bar
log -noname local0. "Selected pool_bar by cookie"
default {
log -noname local0. "NO MATCH by cookie.."
The problem with this approach is that when the client(browser) has multiple(or all) cookies, the default part of the switch will always load balance to pool_foo.
I have two ideas to go about this problem:
1)Delete cookies so that I only have the one cookie I need at all times.
2)Make a variable to determine the “current” cookie across events.
Any help is appreciated. Thank you.
-Kai
Hi Kai,
there are at least two aspects to consider:
1) a URI will start with a slash
character. So the validation has to match a string of i.e “/foo”, “/foo*”, “*foo”
Without a literal slash or a wildcard as
in case you are using globbing you will not get a match.
2) The function
HTTP::cookie names
returns a list. A list cannot be matched versus a jump table as used by the
switch
command.
You want to use exact matches for an exact cookie name by using i.e.:
foreach cookie_name [HTTP::cookie names] {
switch $cookie_name {
"foo_named_cookie" {
return
"bar_named_cookie" {
return
It will be important to use a
return
after running the action for a match to exit the evaluation.
Thanks, Stephan
Hi Kai,
instead of using
(aka. striping the first character) in combination with “foo/” you may want to use just
[HTTP::uri]
in combination with “/foo/”. Both will work, but the later one will save you some CPU cycles.
instead of using
you may want to use
[string range [HTTP::uri] 4 end]
, where “4” represents the number of trailing chars to be removed. Again… both will work, but the later one will save some additional CPU cycles.
The cookie based routing problem you’re experincing, is almost impossible to fix using multiple independend cookie_names. I would recommend to change your cookie based routing logic to use an additional “cookie_name” for both subsites. The value of this cookie would then contain the needed routing (e.g. either “foo” or “bar”). The cookie could be insert by your backend servers or using an
HTTP_RESPONSE
iRule at the time the user visits the URI /foo or /bar. To move between the different subsites, you have to make sure the user visits the URI /foo or /bar initially, to get the new cookie value.
Cheers, Kai
