Is there a roadmap for iRules LX, specifically Node.js support? I’m curious when the version of Node.js will be upgraded to one of the newer branches with more ES2015/2016 support.
I found Babel seems to work okay for using newer features - but with some performance penalties depending on the features you use.
Anyone from PD here?
Hi Jonathan, we wouldn’t be able to share road maps in a public forum. For more information about that question, contact your F5 account team and have them reach out to product management.
BIG-IP 13.1 ships with 6.9.1 as an option
