iRules Heat Map - US Only
Code is community submitted, community supported, and recognized as ‘Use At Your Own Risk’.
Short Description
This iRule is an update to the original by Colin Walker. It takes source IPs and does a geolocation lookup on them and if within a US State, adds that as a counter against that state in the session table memory. A request to /heatmap on the applicable virtual server will display a US map with request counts from each state utilizing Google’s GeoCharts.
Problem solved by this Code Snippet
This is not solving a problem, but is providing enhanced view of data traversing the BIG-IP.
How to use this Code Snippet
  1. Apply the iRule to your application’s virtual server
  2. To view the map, use the URI /heatmap
  3. To clear the data from memory, use the URI /resetmap
Code Snippet Meta Information
  1. Version: Tested on TMOS version 16.1.3, but should work as is on any version 12.1.x forward.
  2. Coding Language: iRules, HTML, and Javascript.
Full Code Snippet
Code is accessible in this gist on GitHub.
