I need to redirect traffic for an application, on 10.184.1.191 (VIP) to any of the two servers ,10.184.1.71:9443, or 10.184.1.49:9443. However, the search string is based on paths.
HTTP:80 and HTTPS:443, path /oauth2/* => https: 10.184.1.71:9443 & 10.184.1.49:9443 HTTP:80 and HTTPS:443, path /authenticationendpoint/* => https: 10.184.1.71:9443 & 10.184.1.49:9443 HTTP:80 and HTTPS:443, path /wso2/* => https: 10.184.1.71:9443 & 10.184.1.49:9443 HTTP:80 and HTTPS:443, path /services/* => https: 10.184.1.71:9443 & 10.184.1.49:9443.
The end servers have dynamic content after the Ip:port combination, example
https://10.184.1.71:9443/authenticationendpoint/login.do?client_id=49i1A1Rd6ErNhFtgAuY1b1ybWNsa&commonAuthCallerPath=%2Foauth2%2Fauthorize&forceAuth=false&passiveAuth=false&redirect_uri=http%3A%2F%2F10.184.1.71%3A9086%2Fclm-ui%2F%23%2Fauthcode&response_type=code&scope=openid&state=openid&tenantDomain=carbon.super&sessionDataKey=94da32df-4304-4bd7-a709-07e6eb14f4fb&relyingParty=49i1A1Rd6ErNhFtgAuY1b1ybWNsa&type=oidc&sp=clm-mtnn-phI&isSaaSApp=false&authenticators=IPAuthenticator:LOCAL.
How do i write an irule in this case
Hi Guy,
Do you want just the users to access only those paths and to load balance. Or do you want to do another thing?
Hello Kazeem,
Try the following irule on the VS_HTTPS
set path [string tolower [HTTP::path]]
switch -glob $path {
"/authenticationendpoint/*" -
"/oauth2/*" -
"/services/*" -
"/wso2/*" {
pool pool_name
default {
log local0. "Fallback for path: $path -- To be defined"
Could you clarify if on VS_HTTP you only want to redirect all traffic to HTTPs or only paths that you specified ?
Regards
Hi Faruk, I want them to access all those paths
