I started using BIG-IP last month,
iRules Editor was fine but i love Noterpad++ so i made UserDefine
I think it will help many people like me so i put it here.
Link: http://www.RealGame.co.il/F5/iRulesDefine-RealGame.zip
How to import: Language → Define Your Language → Import
File Extension: *.irul
I hope someone will take what i made and extend it because mine isn’t perfect.
Updetad: 15/04/2013
Jnon
2
Is there an iRule editor for that Mac that anyone knows about, I use the VIM on my linux box, it would be nice to have a GUI version for the Mac -
Maybe in the future some one will make eclipse plugin for iRules then it will work on any operation system…
I need to find the time for this and learn more about iRules because i’m newb…
I can highly recommend Sublime text; it’s the best editor I’ve come across: http://www.sublimetext.com/ - available for Mac, Windows and Linux
Sublime is awesome! iRules checking should be implemented there.
Arturo
6
DEJ
7
DEJ
8
Thank you very much Dareuja!
Arturo
10
Just finished my own version with syntax highlighting, auto complete and help integration.
Download version can be found on https://bitbucket.org/gstanchev/nppf5
Hope this will help to Notepad++ fans like me
