Irules for a specific tcp ports and https
Hello everyone
I am not expert in F5, and I need help with a VIP for all ports, and I only need to allow the ports 443 and from the TCP 7000 to 7010
Currently I have this configuration:
when CLIENT_ACCEPTED { log local0. “Accepted--start iRule” if {([TCP::local_port] < 7000 ) && ([TCP::local_port] > 7010) && ([TCP::local_port] != 443) } { log local0. “[IP::client_addr] rejected on TCP [TCP::local_port]” reject } if {([TCP::local_port] >= 7000 ) && ([TCP::local_port] <= 7010) } { log local0. “[IP::client_addr] accepted on TCP [TCP::local_port]” pool pool01 } if {([TCP::local_port] == 443) } { log local0. “[IP::client_addr] accepted on TCP [TCP::local_port]” set proto “https” SSL::profile client.clientssl pool http_pool } log local0. “Ended--iRule completed” }
But the https access is not working, I am not able to reach any node.
you can test this irule:
log local0. "Accepted--start iRule"
if {([TCP::client_port] <= 1000  && [TCP::client_port] >= 65000) && ([TCP::local_port] == 443) } {
     do nothing
    log local0. "[IP::client_addr] rejected on TCP [TCP::client_port]"
    reject
For info:
[TCP::client_port]
is your source/local port in your context (clientside)
[TCP::local_port]
is your destination port in your context (clientside)
This article can help you:
regards
