iRules and Monitors
I would like to trigger a monitor check from an iRule, rather than waiting for the monitor’s configured interval to occur. Is there a way to do this on LTM?
I was hoping the monitor would fire when using [active_members ], but it does not appear to do so.
Hi Tarsier,
Unfortunately you can’t directly influence the monitor with iRules - which was done by design from what I understand.
Bhattman
