Iruler hangs on/after connect
I was setting up a virtual edition as a LAB-box.
Knowing the iruler on my ancient win2K box couldn’t be updated past iruler version 10.1.0, I tried installing iruler 11.1 on my laptop running vista (32b).
Trying to connect to the bigip-ve, I first got an error as mentioned here in the fora ( Invalid connection information ) which was quicly solved/avoided by not saving the config. . . at least it looked that way.
I can connect to my production 3600 boxes running v10.1 without a problem using the v 11 iruler.
I can connect to the bigip VE 11 with my old v10 Iruler but i asume it will be lacking functionality. ( ie only offline and local-traffic shown in left pane not configuration)
While connecting the iruler v11 to the v11 ltm-ve the application hangs with the application-statusbar stating “disconnected. click the connect button” and the statusbar of right pane stating “connected to 192.168…”
After waiting a very very long time I get an error message (pasted below without the assemblies) and the left pane has 3 nodes ( configuration , local traffic & offline ) but no rules show up.
Kind regards
Ivo
************** Exception Text **************
System.InvalidOperationException: There is an error in XML document (949, 20). ---> System.Net.WebException: The operation has timed out. at System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.StreamReader.ReadBuffer(Char[] userBuffer, Int32 userOffset, Int32 desiredChars, Boolean& readToUserBuffer) at System.IO.StreamReader.Read(Char[] buffer, Int32 index, Int32 count) at System.Xml.XmlTextReaderImpl.ReadData() at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars) at System.Xml.XmlTextReaderImpl.ParseText() at System.Xml.XmlTextReaderImpl.ParseElementContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlTextReader.Read() at System.Xml.XmlReader.ReadStartElement() at System.Xml.Serialization.XmlSerializationReader.ReadStringValue() at System.Xml.Serialization.XmlSerializationReader.ReadTypedPrimitive(XmlQualifiedName type, Boolean elementCanBeType) at System.Xml.Serialization.XmlSerializationReader.ReadReferencingElement(String name, String ns, Boolean elementCanBeType, String& fixupReference) at System.Xml.Serialization.XmlSerializationReader.ReadReferencingElement(String name, String ns, String& fixupReference) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderLocalLBRule.Read8_LocalLBRuleRuleDefinition() at System.Xml.Serialization.XmlSerializationReader.ReadReferencingElement(String name, String ns, Boolean elementCanBeType, String& fixupReference) at System.Xml.Serialization.XmlSerializationReader.ReadArray(String typeName, String typeNs) at System.Xml.Serialization.XmlSerializationReader.ReadReferencingElement(String name, String ns, Boolean elementCanBeType, String& fixupReference) at System.Xml.Serialization.XmlSerializationReader.ReadReferencingElement(String name, String ns, String& fixupReference) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderLocalLBRule.Read24_query_all_rulesResponse() at Microsoft.Xml.Serialization.GeneratedAssembly.ArrayOfObjectSerializer30.Deserialize(XmlSerializationReader reader) at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle) at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at iControl.LocalLBRule.query_all_rules() at iRuler.iRulerMain.refreshiRules() at iRuler.iRulerMain.DoConnect() at iRuler.iRulerMain.toolStripButton_Connect_Click(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
