irule with source IP
Hi I new in F5, I need help to configure an IP irule with Origin, it is routed to a particular node with its respective port.
Thank for the help.
Are you referring to a NAT or a virtual server implementation?
I mean A Virtual Server implementation. I need depending on what source IP Determined send a node without. thanks
Here’s an example iRule:
Or you could look at AFM for a fully featured firewall approach:
Aaron
A very basic implementation might look something like this:
  1. Define an address-based data group. Example (my_ip_datagroup):
    10.10.10.10 := 192.168.42.10 80
    10.10.10.11 := 192.168.42.11 80
    10.10.10.12 := 192.168.42.12 80
  2. Create an iRule:
    when CLIENT_ACCEPTED {
        if { [class match [IP::client_addr] equals my_ip_datagroup] } {
            node [class match -value [IP::client_addr] equals my_ip_datagroup]
