On Netscaler migration I come to a rule that could not solve.
On netscaler responder rules there is a drop rule related with this regexp line. I wonder how can i write this on f5 irule.
Netscaler Rule HTTP.REQ.URL.PATH_AND_QUERY.AFTER_REGEX(re/\?/).BEFORE_REGEX(re/:/).REGEX_MATCH(re/(action$|redirect$|redirectAction$)/)
Can anyone help me to write this as F5 irule.
Thanks friends.
api drop rce
if {
([HTTP::query] starts_with "action:") ||
([HTTP::query] starts_with "redirect:") ||
([HTTP::query] starts_with "redirectAction:")
} then {
reject
I try this one but it does not work.
you can try to use this one (log is optional):
if {[HTTP::uri] contains "action" or [HTTP::uri] contains "redirect" or [HTTP::uri] contains "redirectAction"} {
log local0. "Query string of URI is [HTTP::uri]"
reject
No we are not looking for contains. Cause. It can pass first quest with redirect1: but can not be redirect: or redirect: word can pass later of the url.
I wrote a polict with starts_with and all solved for now.
If you break it down like this:
HTTP.
REQ.
URL.
PATH_AND_QUERY.
And based on this reference:
I think what it’s basically saying is this:
- Start with the full HTTP request URI (path, query string, and all)
- From that, return the string that is after the question mark (?)
- From that, return the string that is before the colon (
- And if the resulting string ends with ($) “action”, or “redirect”, or “redirectAction”, then drop the request.
So then the resulting iRule might look like this:
if { [regexp -all {(action|redirectaction|redirect)} [string tolower [findstr [HTTP::uri] "?" 1 ":"]]] > 0 } {
drop
Or, if you wanted to avoid the regex:
if { ( [string tolower [findstr [HTTP::uri] "?" 1 ":"]] ends_with "action" ) or ( [string tolower [findstr [HTTP::uri] "?" 1 ":"]] ends_with "redirect" ) or ( [string tolower [findstr [HTTP::uri] "?" 1 ":"]] ends_with "redirectaction" ) } {
drop
Or:
switch -glob [string tolower [findstr [HTTP::uri] "?" 1 ":"]] {
"*action" -
"*redirect" -
"*redirectaction" {
drop
default {
return
Thanks alot. Perfectly worked. I solved it with writing policy rather then i rule. Now i am going to remove policy i wrote and apply this irule.
be well and take care Kevin.
