iRule with a global Variable
When I set a value for a global variable in iRule and CMP is enabled on the VS, is there a way to share the global variable stored value across more than one TMM ??
I don’t wanna disable CMP but at the same time I want to use a global variable and it’s not shared across TMMs…is there a workaround ??
i think you are asking how to share data among TMMs without demoting CMP, aren’t you?
if so, have you ever tried table command?
v10.1 - The table Command by Spark
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/2375/v101\-\-The-table-Command\-\-The-Basics.aspx
Awesome !
Thanks very much Nitass
