Irule v9 --> v11
Hello,
On BigIP V9 I have an Irule
An extract :
when CLIENT_ACCEPTED {
set DefaultValue “::DefaultValue[virtual name]”
if { [class exists $DefaultValue]} {
set myRedirectRow [findclass “ForbiddenUrl” [set $DefaultValue] " "]
if { $myRedirectRow ne “” } {
set myRedirectMethod [getfield $myRedirectRow " " 1]
But with V11, I think that i have a problem with the syntax :
Because [virtual name] return /Common/
On V9 [virtual name] returne only
Do you have an idea ?
Hi vallesm77,
Check this related thread for some options to parse the virtual name from the path:
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/2158968/showtab/groupforums/Default.aspx2234683
You might also consider updating your iRule to use the full virtual name as the data group should have a folder as well.
Also, if you’re running on a CMP capable platform you should try to avoid using global variables like “$::defaultValue”. You can set $static::defaultValue in RULE_INIT instead:
http://devcentral.f5.com/wiki/iRules.static.ashx
Aaron
