(version 9.4.7) I have been restricting access to certain pools via the following iRule statement:
if { [matchclass [IP::client_addr] equals $::TrustedIPs] and [matchclass [HTTP::path] starts_with $::SomeURIs] } {
pool secure_pool
return
else {
pool public_pool
return
The SomeURIs class contains elements like “/foo” and “/bar”. It seems like when I use a double slash, i.e. “http://myvirtualip//foo” the iRule statement doesn’t come into effect. Thoughts, considerations?
The [HTTP::path] starts at the first “/” so you will either have to account for it in your matchclass or add to your iRule to look for it and remove it.
HTTP::uri [string map {"//" "/"} [HTTP::uri]]
Wiki Entry for [HTTP::path] - http://devcentral.f5.com/wiki/default.aspx/iRules/http__path.html
Posted By Michael Yates on 05/21/2010 03:04 PM
Awesome, thanks, I’ll test that later.
Is there any major advantage to performing the string map replace on the HTTP::uri vs the HTTP:path? We use extensive URIs and probably don’t need to evaluate all the params in them.
Even more importantly, what about replacing any amount of slashes with a single one? How can I string map look for a series of slashes and replace them with only one?
string map can’t recursively perform substitutions:
http://www.tcl.tk/man/tcl8.4/TclCmd/string.htmM34
string is only iterated over once, so earlier key replacements will have no affect for later key matches.
You could either loop string map while there aren’t instances of // or you could use regsub to search for //+ and replace it with /. However, if you’re trying to handle obfuscation techniques, there are many more to account for than multiple forward slashes. As you’re whitelisting based on IP address, obfuscation attempts might not be so much of a concern though. See these recent posts for more examples:
irule based on ip and url
http://devcentral.f5.com/Forums/tabid/1082223/asg/50/showtab/groupforums/aff/5/aft/1171094/afv/topic/Default.aspx1171131
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=3090031324
Aaron
