Hello, I have question on “irule” for whitelisting. Currently we’re using IP as source or destination and that is working correctly as mechanism for directing traffic towards bypass path. The question is – how (if) we can add FQDN (or actually entire domains i.e. Microsoft – related to Office 365 and Skype for Business as example) on the top of IP listings? Regards
Just to clarify, here is the irule that we’re using based on IP. How this can be modified to include FQDN or domain as destination.
when RULE_INIT {
Debug logging level (0 = logging disabled, 1 = logging enabled)
set static::_proxy_bypass_debug 0
Proxy Bypass Source IP datagroup name (as configured under Local Traffic > iRules > Data Group List)
set static::source_ip_proxy_bypass_RD1_dg "/Common/source_ip_proxy_bypass_RD1_dg"
Proxy Bypass Destination IP datagroup name (as configured under Local Traffic > iRules > Data Group List)
set static::destination_ip_proxy_bypass_RD1_dg "/Common/destination_ip_proxy_bypass_RD1_dg"
when CLIENT_ACCEPTED {
If client IP is in bypass list then don't load balance client to ironports, otherwise load balance to default pool.
if { not (([class match [IP::client_addr] equals $static::source_ip_proxy_bypass_RD1_dg]) || ([class match [IP::local_addr] equals $static::destination_ip_proxy_bypass_RD1_dg])) } {
if { $static::_proxy_bypass_debug } { log local0. "Client connection proxied to ironports. Client Source IP [IP::client_addr] or Client Destination IP [IP::local_addr] is not in Datagroups. Server selected is [LB::server]" }
return
if { $static::_proxy_bypass_debug } { log local0. "Client connection not proxied to ironports. Client IP [IP::client_addr] or Client Destination [IP::local_addr] is in Datagroups." }
forward
Just add a datagroup containing the hostnames and use [HTTP::host] as additional match condition in your “if”.
if { not (([class match [IP::client_addr] equals $static::source_ip_proxy_bypass_RD1_dg]) || ([class match [IP::local_addr] equals $static::destination_ip_proxy_bypass_RD1_dg]) || ([class match [HTTP::host] equals $static::destination_fqdn_proxy_bypass_dg])) }
I didn’t test this, but it should work.
