I am trying to create an irule that will search the TCP response from a server for the userData: value and them persist based on that. The irule is below, which i have associated with a Universal persistence profile, but when i try to initiate a connection, no connection is being established to one of the load balanced servers. If i remove the persistence profile i am load balanced fine:
It appears that if i reduce the TCP::collect value, i get connected. However i only get connected if i set the value to 19 or below:
TCP::collect 19
Which is fine as far as connecting goes, however i guess this means that the irule is only collecting 19 bytes of data, which isn’t enough to find my search string.
