Can anyone please help to create an irule for below requirement.
I have created two datagroups in my f5 for source ip as well as url list
IP data group name : allowed_IP URL data group : allowed_url
We would like to deny the access if the request is only for www.abc.com/xyx but the same time it should allow when it comes for www.abc.com/xyx/ccc.
URL to be allowed
www.abc.com/xyz/ccc www.abc.com/xyz/yyy www.abc.com/xyz/ppp www.abc.com/xyz/ooo
URL to be blocked
www.abc.com/xyz
So if a request comes for the allowed_url list , it should allow for all But if it is for only www.abc.com/xyz ,allow only for the Ip address data group “allowed_IP” .Rest all should be blocked.
Hi Sanalbabu,
I’ve written two different versions for you, to optimize the performance based on your expected request pattern. So please estimate your expected request pattern and then either use the outlined iRules of senario1 or scenario2.
Scenario1
The iRule below should be used, if you expect many request to trigger the IP-based allow list for /xyz.
when CLIENT_ACCEPTED {
if { [class match [IP::client_addr] equals DataGroup_ALLOWED_IP_ADDR] } then {
set my_trusted_clients 1
set my_trusted_clients 0
if { [string tolower [HTTP::host]] equals "www.abc.com" } then {
set low_uri [string tolower [HTTP::uri]]
if { [class match $low_uri starts_with Datagroup_ALLOWED_URIs] } then {
You may insert additional iRule code here, to handle request to the explicitly allowed sub-sites
} elseif { $low_uri starts_with "/xyz" } then {
if { $my_trusted_clients } then {
You may insert additional iRule code here, to handle request for the explicitly allowed client IPs
Insert your block code here, to handle the blocked requests
Below are some examples...
1.) Sending a redirect
HTTP::redirect "http://www.somesite.com/errorpage.html"
2.) Sending a errorpage
HTTP::respond 403 content "Access denied"
You may insert additional iRule code here, to handle request to other sub-sites
You may insert additional iRule code here, to handle request to other sites
Scenario2
The iRule below should be used, if you expect just a few request to trigger the IP-based allow list for /xyz.
Cheers, Kai
Hi Kai,
Thanks for your support.
I have tested with this in my F5 but it is still allowing url /xyz.
Thank you Sanal Babu
Hi Kai,
Also no where in the irule it says drop or allow . I am not good in iRule. Just a thought.
Hi Sanalbabu,
there does not exist a “allow” or “drop” action. If you want to “allow” traffic, you have to perform “nothing”.
For the “drop” part I’ve already included two different command samples for you and also a lot of comment lines where those commands can be insert base on your detailed requirement…
Hope this helps…
Cheers, Kai
Hi Sanalbabu,
Hope this helps…
Cheers, Kai
