iRule: URI Rewrite for request to node
I need help with an iRule. I need to have the URI change abc.domain1.com when sent to the VIP to xyz.domain2.com when the request is forwarded to the node. I am running version 11.5.3
If you just need to translate the uri on the request side, you can use the following irule
in bigip v11.5+
    HTTP::host "xyz.domain2.com"
for older versions :
    HTTP::header replace "Host" "xyz.domain2.com"
