Hello All - I need help to fix the below iRule
Requirement is when the user types in https://apple.api.com/e/apple/console/ the uri /e/apple/ should be replaced by /console so its going to be https://apple.api.com/console/ The below iRule accomplishes that but when user types in https://apple.api.com/e/apple/console without the ‘/’ after console it does nothing. It only works when user types ‘/’ at the end.
log local0. "Incoming URI = [HTTP::uri]"
if { [string tolower [HTTP::uri]] starts_with "/e/apple/" } {
set uri [string map -nocase {"/e/apple/" "/"} [HTTP::uri]]
log local0. "New URI = $uri"
HTTP::uri $uri
virtual apple.api_vs_4001
log local0. "Host header is [HTTP::host]"
Can we assume the log statement is returning the correct value?
When you say “it does nothing”, can you elaborate?
Can the server actually handle the URL without the trailing “/”?
Hi Domai,
I understand your problem. If you not put / after console at the end of th uri, it’s not working. I advise you to rewrite your uri in order to add “/” at the end of uri if it’s not present.
Please try this Irule, it will fix your problem
if { [string tolower [HTTP::uri]] contains "/console/" } {
set uri [string map [ list "/e/apple/" "/" "/console" "/console/" ] [HTTP::uri]]
HTTP::uri $uri
Keep me in touch if it working for your.
Regards
Hello Kevin when I say nothing I meant that page does not load it just hangs.
I don’t see anything particularly wrong with the iRule logic, so I have to wonder if the server actually understands the “/console” URI (vs. “/console/”).
And the log statement is returning the correct value only when user types in /in the end or else it does not return the correct value. For example when user types /p/apple/console/ it shows incoming uri as /p/apple/console/ and new uri as /console/
But when user types in /p/apple/console, it shows incoming uri as /console/ and that that is it.
This may require deeper inspection of the HTTP traffic flow, as there maybe client side processing affecting the interaction. Can you display the results of a simple Fiddler capture (with both URLs)?
I have the screenshot…can I get your email so that I can mail it to you directly. I am unable to upload it here using insert image option.
Sent you a private message
