I’m working on finding a solution for being able to match a query parameter by string and essentially “find and replace” the parameter using an iRule? Something that would essentially look like the following:
I apologize, I think I missed one of the problems I ran into with this. There is also a parameter in the URI that is randomly generated (i.e. &userID=sdfoajc391!90sjvdm3wdfs) so matching on a static URI wouldn’t be possible.
